1 have you got a big intecooler ?
2 are you running over 10psi ??
if so the turbo sucks heaps of air in while spooling up to fill the cooler and this registers on the AFM as running over 14 psi so feuel cut comes on
once cooler is pressurised the airflow reduces and all is sweet again
to fix this situation get a fuel cut defender installed
martin
Check the air filter. If you have a pod filter, is it heaps dirty? If so, wash it or buy a new one. If it's stock. clean it also. To see if its the pod causing the trouble, take it off and drive it around the block once or something (dont drive too far or through any dirty areas with it off tho!)
If the lag is gone, it was because the filter is too dirty. This happened in a friends car not long ago, we were wondering why it was going dead at low RPM, it was because the filter was clogged and the engine wasnt breathing properly.....
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
