Hey kids,
I got a MASSIVVEEEE stack of rubber here, as you can see
I need it all gone
I dont want it
I dont need it
SO WHO WANTS IT ALL?
$500 for all this.. come and take it off me.. get your truck/ute/ trailer and take it all
4x 255/55/18 Goodyear Wrangler HP– nice even wear on all four of them, about 40% left aswell $200
4x 205/60/16 Michelin Vivacy – 50% left, all even wear $150[sOLD
4x 205/40/17 Nankang Ultra Sport NS-II – 2 have around 20% left, other 2 have 55%, even wear $150
4x 225/55/17 Bridgestone Turanza ER30 - about 25-30% left on them, all even wear $120
3x 205/55/16 Bridgestone Turanza - 50% left on all three of them $200
3x 185/55/15 Bridgestone Potenza RE040– about 50% left on him $200
3x 215/60/15 Brisgestone RE711– 50% all round, good even wear, very aggressive looking tyre $150
2x 235/40/18 Fullrun HP199 – some slight camber wear, about half way through – 50% left $150
2x 235/45/17 Nankang Ultra Sport NS-II – got some camber wear on them, about 35% left $125
2x 205/45/17 Silverstone – probably best for track events as they have some camber wear $50
2x 235/45/17 Khumo Ecsta – some camber wear on the inside $120
2x 205/40/17 Silverstone FTZ Sport– one has some camber wear and the other has about 80% $120
2x 255/55/17 Bridgestone Turanza ER30– about 40% left on it with even wear $80
2x 205/55/16 Bridgestone Turanza ER30– one has about 80-90% left and the other about 60% left $120
2x 225/50/16 Firehawk Wideoval - aggressive looking tyre, got 40-45% with even wear all round $100
2x 225/55/16 Khumo Ecsta – one of them has some camber wear, the other about 60% left on it $75
2x 195/65/14 Barum Bavavis – best for scrubbing out for track & cruise events $20
2x 185/65/14 Yokohama S220 – 20-25% left on them with all even wear $20
2x 155/65/14 Toyo J36 - one of them is worn and the other has 40%, good for burnouts $20
1x 215/35/18 Toyo Proxies F24– about 70% left on it $ 50
1X 205/45/17 Nexan N3000 – he has about 40% left on him $50
1x 215/45/17 Bridgestone Potenza RE040 about 25% left on him $45
1x 205/60/16 Bridgestone GIII– got about 45% left with even wear $50
1x 195/50/15 Potenza GIII– 45-50% left on it, great tyre with awesome performance and reviews $50
BRISBANE
PM PM PM PM PM
0420 926 501 < TEXT/SMS ONLY!!
DAN> Fs: Qld - Rubber Rubber And More Rubber
I'm after 18s 235/35 x4 and/or 245/35 x 4 - if you could send me a PM with a price, that'd be good thanks.
Edited by KustomR33
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
