from what I know, the GT-R bonnet size (due to slightly larger guards) will be slightly a bit larger. However, I think the gap is unoticable and should be bolt-on. I stand to be corrected though.
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3386268
i know that with the r32 they bolt straight on. i have a mate with one. the weight difference is noticable. when i first lifted the bonnet on my mates 32 i nearly threw it over the roof.
but i hope you got a bit of spare coin to pay for it. they aren't cheap.
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3386624
As per mod082 the weight difference is very apparent....I went from owning a 33 gtst to 33 gtr and nearly 'threw it over the roof' as well!! :bunny:
I have never actually fitted a gtr bonnet to gtst but have *heard* that it requires mods due to the wider guards and different latch position.....best to get the word from someone who has actually done this though....
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3386776
Hmmmm...thanks for the info guys. I'm not worries about the cost because the weight saving outweighs it, plus it'll be cheaper than a $1000 carbon fibre bonnet ;)
Only off putting thing is having to mod to bolt it on, plus it needs a respray to match my R33...
Is it worth the hassle?
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3387127
not by much.
but either way, the money you spend on this weght saving exercise could be spent on getting more power which will have more of an effect and outway the negative of the heavier bonnet.
or just pull out your stereo
plus carbon bonnets are illegal as far as i know
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3387786
Ive done this to my car.. and it wont fit straight up..unless you change the hinges, move your headlights foward about an inch, relocate latch and maybe change the guards. the weight difference is substantial i'd say its probably 70% lighter. I'd personally wouldn't bother as it will cost more than what a carbon bonnet would.
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3387818
Damn sounds like a great mod! Would definitely improve all-round performance. Gtst's have a really heavy front end, so much damn iron in the engine bay and chassis.
Sounds like a mission, before i even respray the mofo :)
Ahhh well, guess the only option is a hi-flow turbo instead...sigh :P
https://www.sau.com.au/forums/topic/187667-r33-gtr-bonnet/#findComment-3388154
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
