ryan if i had the cash i would buy urs!!
i love it! follwing u home the other night and watching ur exhaust popping ambers on limiter was sexual!
perfect example of a 33!
pm me a price hahaha
While i have a spare minute, amongst all this moving house hassle,
id like to give Ryan (Ryanrb25) i plug!
he did my timing belt, and water pump today,
GREAT JOB! did every thing right the first time, and took his time to ensure the job was done properly!
treated my car as if it where his own!
he even organised the parts for me, i didnt do a thing!
best of all, it was by far cheaper than a mechanic!
if you need anything done, and not sure how to do it yourself, and dont wanna pay an overpriced mechanic,
be sure to drop him a PM!
he's a champ
thanks again ryan, she is running sweet!
:P:D
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
Yeah that would be good thanks Ryan :P Im guessing the injectors are easy to fit, so ill try and do them myself, and the Nismo pump.
Just make sure before you do it chad, The plugs on your standard injectors fit the Sard Injectors, May need to change them, but that may just be Side fed's on the rb25. Just make sure just incase, You dont want to rip the rail out and realise they wont fit. I'll try sort out these correction values and let you know.
Has anyone bought items of a store on ebay called Lewis engines performance engines1? they have RB 20/ 25 ARP head stud kits for $265 + $15 postage.
Also What should i be paying for a r33 gts-t OEM thermostat or should i go nismo, iv herd running a nismo thermostat can cause probs with a street car?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
