ryan if i had the cash i would buy urs!!
i love it! follwing u home the other night and watching ur exhaust popping ambers on limiter was sexual!
perfect example of a 33!
pm me a price hahaha
While i have a spare minute, amongst all this moving house hassle,
id like to give Ryan (Ryanrb25) i plug!
he did my timing belt, and water pump today,
GREAT JOB! did every thing right the first time, and took his time to ensure the job was done properly!
treated my car as if it where his own!
he even organised the parts for me, i didnt do a thing!
best of all, it was by far cheaper than a mechanic!
if you need anything done, and not sure how to do it yourself, and dont wanna pay an overpriced mechanic,
be sure to drop him a PM!
he's a champ
thanks again ryan, she is running sweet!
:P:D
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
Yeah that would be good thanks Ryan :P Im guessing the injectors are easy to fit, so ill try and do them myself, and the Nismo pump.
Just make sure before you do it chad, The plugs on your standard injectors fit the Sard Injectors, May need to change them, but that may just be Side fed's on the rb25. Just make sure just incase, You dont want to rip the rail out and realise they wont fit. I'll try sort out these correction values and let you know.
Has anyone bought items of a store on ebay called Lewis engines performance engines1? they have RB 20/ 25 ARP head stud kits for $265 + $15 postage.
Also What should i be paying for a r33 gts-t OEM thermostat or should i go nismo, iv herd running a nismo thermostat can cause probs with a street car?
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
