thats what im scared of, dissappointing him.......
may i ask how you found him ruby? pm if need be
I got introduced to a cousin a never knew i had. He gave me info on my older brother who was in the forces. After a few months of gaining their trust, they gave me my brother and fathers address and I made contact.
LOL. and wow, that bodywork is beyond description :S
Bought an R32 GTR V-SPEC II shell for my drift car today. SHE RUNS!!!! heaps excited to get it out to a carpark
i'll race ya Damo, i got a two speed nitro car :) its set up for grip though :(
I got a S15 petrol car. Haven't used that thing for awhile..
got your car fixed yet mate?
ill be out cruisin sat night, missus has some girls night in charity party thingymajig.....
any one else be out?
I might be out ... but if the weather is nice, I'll be on the bike :)
Went for a ride yesterday with Kell on the back for my last day off before going back to work. Wasn't too bad for a ride.
lol, reminds me of when i was a kid, used to take the rubber off my rc car,
wet mums kitchen tiles with a mop and go sideways lol, that was before i even knew what drifting was
yeah this weekend is gonna be purrrrect for a cruise.....
bit of hills, bit of bay bit of semaphore bit of regency lol :)
33 on sunday!!
f**kin drift car is hard to handle, need more grip on the slicks.
best drift tyers to use is 2inch pvc pipe and have around 5mm sticking out from the rim's to stop damage to the rim when you hit somthing :)
So.
My dad was home extremely early yesterday from work. Walk inside, ask him why hes home early....he says "go have a look at the back of the corolla....and take your camera"
and here are the results lol:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
