haha, that's great.
When I worked at Adelaide Engine we used to sell second hand Scania & Volvo pistions for $20 as they made great ashtrays (ie. the combustion chamber is built into the top of the piston).
SLED, spoke to a good friend of mine tonight who is a tech at toyota, There is a recall on the 200. The vaccumm pump accumulator valve opens far too much causing the motor to burn excessive oil...This can be fixed with a simple flash of the ecm. Toyota do it on warrentee, Also if you get a spungy brake pedal it's because the Diaphram in the master cylinder has a slit in it rather than a hole..hard to explain over the net. But Minor things and will be fixed for free.
So many lines up for grabs these days! Infact, even I'm barely keeping hold of the GTR. Still up in the air about if I'll sell it, or keep it...
If my $ improves, then I'll keep it for another year!
haha im in the exact same sittuation, gotta figure out what i wanna do before the years insurance is up. very very tempted to go down the chaser route
^ i know you guys are confused now so im going to pretend you didnt just say that :(
godzilla can not be replaced by some sort of "chaser" possible meaning to the name lagging behind :D
and pete keep your damn hands off mine :( and if you mod a vspec 2 32 there will be some gheto like behaviour out of me
Edited by Inline 6
ah, thanks for the heads up.........I'll print this out and point these things out when I get the service done :(
but seriously mang, your money, your choice, no point the whole of SAU telling u to get volks, and you wishing for the rest of your rim ownership that u got gtr's... maybe you can get gtr and spend 600 on brakes? id go gtr and rotor upgrade over the 37's.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
