Hi Guys,
I have a Series II Drivers Door White in Colour complete with 20% tinted glass (which is in the down position for storage),power window,motor & mirror,and lining and all switches Immaculate condition$200 ) Will seperate. SOLD
The Door is in immaculate condition inside and out and all swithes and motors work like new. Complete door just needs speaker.
THE DOOR IS SOLD AS IS EVERYTHING THANKS A HEAP!!!!!!! Cheers Jeff
Edited by STYLINE
  • Replies 55
Drivers side Front Guard $100
With Nismo Clear Indicator lens and GT Badge, Excellent condition, unmarked..
Edited by STYLINE
Hey mate, i want to buy the headlight, im in townsville QLD, really keen can you plz organise freight will pay extra..
cheers Todd
cheers Todd
Hi Todd I will see how much postage to Townsville will be I will let you know tomorrow as Post Office is closed.
Cheers Jeff
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
