Hi Guys,
I have a Series II Drivers Door White in Colour complete with 20% tinted glass (which is in the down position for storage),power window,motor & mirror,and lining and all switches Immaculate condition$200 ) Will seperate. SOLD
The Door is in immaculate condition inside and out and all swithes and motors work like new. Complete door just needs speaker.
THE DOOR IS SOLD AS IS EVERYTHING THANKS A HEAP!!!!!!! Cheers Jeff
Edited by STYLINE
  • Replies 55
Drivers side Front Guard $100
With Nismo Clear Indicator lens and GT Badge, Excellent condition, unmarked..
Edited by STYLINE
Hey mate, i want to buy the headlight, im in townsville QLD, really keen can you plz organise freight will pay extra..
cheers Todd
cheers Todd
Hi Todd I will see how much postage to Townsville will be I will let you know tomorrow as Post Office is closed.
Cheers Jeff
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
