http://www.pavtek.com.au/pp_rebuildkits.html
This is a rebuild kit for a RB30ET so for $700 od dollars which includes:
Hypereutectic pistons & rings
Mains and big end bearings
Cam bearings
Full gasket set
that would mean that the pistons are worth bugger all maybe $400-500?
I priced new pistons from Nissan RB30E just standard NA pistons and they were $720.
I've emailed them so i'll let you know what I come up with....
That it is.. I'm waiting for a response.. I quizzed him regarding a slightly higher compression ratio or using the specs from a set of NA pistons etc.. ;)
But yer I'll keep you posted.
If the pistons are 400-500 I might grab a set and slap them in before the head goes on. Worth it really especially for only 400-500. Providing they are good that is.
Forged ARIAS RB30E Pistons and rings are $1600. :eek:
I thought it might be worthwhile mentioning that high-silicon content pistons (Hypereutectic) are extremely intolerant of pinging. The are a very brittle piston weaker even than stock cast pistons (in regards to detonation). Their benifits are low expansion and very light.
Any pinging will most likely knock these pistons apart. Be carefull guys.
edit: well not weaker than standard pistons, i mean more brittle
Ahh ok thanx peoples..
That throws that idea out of the window.. I was under the impression that those pistions where better than standard pistons hence inbetween forged and standards.
Oh well.. ;) Stick with the standards then.
I read that too on the internet but its only ever written on the sites of places that sell them :) hehe
I just remember that they dont like pinging. You cant mess with the best (forged) in terms of sheer strength.
I personally think that the hypereutectic pistons would kick ass in a NA engine were there is no huge heat / nasty cylinder pressures / razor edge of detonation.
get hypereutectic pistons, light weight, less stress
get a decent tune
dont let it png, decent aftermarket ECU, a cooler and a normal boost level should be ok.. so i am hoping :)
some of the VL boyz i have spoken to reckon that everyone is crazy for using stock NA pistons with an 8.3:1 CR.... they say that more than 15psi on NA pistons will break them etc
i also noticed that they are more inclined to shave the pistons back to 8:1 where as the skyline guys want to move closer to 9:1
To say dont let it ping, i dont know of anyone that MEANT to detonate their engine. I would personally like a bit of room to feel comfortable. Say for example you make 1 ****up with a boost controller you could lose ya bottom end?
Whatever rings your bells i suppose :)
I cant remember if i was reading a magazine or a thread here that someone mentioned that it was rarely the pistons that go; more likely to be rods due to more concentrated force/unit area? SydneyKid?
Originally posted by -Joel-
I am also aware of the VL boys that run such low comp ratios.. Why I'm not sure.. Maybe they have more issues with detonation due to head design????
Perhapes this is because the VL boyz are only running a SOHC 12 valve head. To compensate for the lack of genral flow in the combustion chamber they have to run lower compression ratios.
And with those T04s, = more air = gasses not escaping quick enough because theres not enough flow in the head = detenation = lower compression ratios = less detenation :P
Hope that makes sense.
CHeers,
Trev
There is a thread that explains the relevance of boost and piston damage - basically detonation causes piston damage, not boost pressure - to qualify, boost pressure increases heat which may push a cylinder over the detonation threashold, but it is not boost directly - you just cant say xxpsi will stuff NA pistons, as long as you keep detonation at bay.
And I agree totally with raist60. Especially once you go down the mod path, engines do ping from time to time with changes in climate, fuel etc. Almost impossible to completely eliminate. Quite often even a knock sensor wont pick up ping.
TonyGTSt: there is a thread about forged pistons and $$, fatz says he can get forged pistons and rings for $1100/set of six.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
