Thats true..
had any one thought about the possibility that the reason why we can run so much boost and power with the standard internals compared to the VL's is that the RB20/25/26 motors have oil squirters?
Sounds good... I'm going to start looking in to how a RB30 bottom end bolts in to a R32 GTR.
I'm tired of 2wd no traction. :(
I am probably dreaming still as my budget is max 25k. All the GTR's around here I have seen are 35k. And even then the one down on Anzac Highway (Silver One) has had a few bingles as the gaps etc don't line up and the under body has been freshly painted. Some thing just didn't look right with it.
Ive said this before in previous threads. If u get hyper pistons, i sure as hell hope u dont drive in summer, cause a just a few seconds of ping and u can blow a hole in em. And hey there also alot more likely to ping too due to the higher silica content refecting more heat into the combustion chamber.
Cheap
Fast
Reliable
Pick any 2.
Hi guys, Its pretty simple really, an RB30 being a 2 valve engine does not flow as well as RB20/25/26's with their 4 valve heads. So to make decent power they have to run a lot of boost, rule of thumb 5 to 6 psi more to make the same power. Such high boost requires lower compression ratios, rule of thumb 0.5 lower for the same power.
My experience, comparing compression ratios for 2 and 4 valve heads is a waste of time. On the flow bench we typically see 30% more flow out of 4 valve heads with similar capacity.
Hope that adds to the discussion.
Another thing with Hypereutectic pistons is they tend to shatter rather than just break or crack ring lands like cast or forged pistons. Also some forged pistons also have a high silicone content so be careful if your thinking of running Nitrous.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
