Clearing out a few R32 parts:
- RS*R 3.5 inch mid section pipe and centre muffler from R32 GTR/GTST $40
- Stock S15 springs (no shocks) came off an ADM S15 with 64,000km on it - VGC - $50
- R32 Boot Trim - all 3 pieces $40 ono
- R32 Boot Carpet $30 ono
- R32 stock turbo intake pipe $15 delivered
- Brand New - Apexi 4.5inch exhaust silencer $40 delivered
- Stock Space Saver wheel (Good cond - heaps of tread) $50 ono
- Stock RB20DET injectors - $10 each.
- R32 front brake discs $20 ono ****FREE with any purchase!!!**** (not postage tho)
- R32 chipboard panel that sits on top of spare wheel in boot (whats it called?) - $15 ono
- also have a Nankang Ultra Sport NSII 255/40 17 95% tread $75 ono
- R32 powersteering pump mounting bracket - $15
- R32 rear pods - SOLD
- R32 sideskirts - SOLD
- Trust steel gear knob - SOLD
- R32 power steering pump - SOLD
- Brand New - 4.5inch universal exhaust silencer - SOLD
- HICAS lockbar & rose jointed tie rods (rose joints worn) - SOLD
- Turbosmart BOV non-plumback (has a scrape on one side) works perfectly - SOLD
- turbosmart boost controller - SOLD
- R32 half stock airbox - SOLD
- Stock RB20 fuel pump running perfectly when taken off car - SOLD
- Pair of R32 type-m foglights (no cracks) - SOLD
- 3" Rear muffler with 4.5" tip - SOLD
- 1 x stock dump & front pipe - SOLD
- 1x HKS cast iron dump (currently has a 2.5" front pipe attached in pics) - SOLD
- 1 x 2.5inch front pipe (mild steel) - SOLD
- Stock RB20 turbo & actuator - good condition when removed from car - SOLD
I'll get pics soon - but y'all know what this stuff looks like.
located in Geelong. but can deliver to Melbourne west or Melton if needed.
will post at buyers expense.
PM me if interested
update with pics!
Added:
- HKS Pod filter 80mm $20 delivered
- 'RUSH' Pod Filter with adaptor to suit RB20/25 AFM $15 delivered
- R32 half stock airbox $25 ono
& pics of BOV.
Hey mate, how many kms on the turbo roughly? And any shaft play at all? thanks.
Also dood, what condition are the gtst wheels in, and just a rough % of tread left on the tyres. Pics would be a big help!
Cheers.
edit: also, i'm very interested in,
- 1x HKS cast iron dump (currently has a 2.5" front pipe attached in pics) $40
- 1 x 2.5inch front pipe (mild steel) $20
- Pair of R32 type-m foglights (no cracks) $40 ono
I'll wait to hear about those wheels first. :ermm:
Edited by _x_FiReStOrM_x_
  • 4 weeks later...
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
