I just bought some new turbos for more power so these need to go.
There R32 N1 turbos with no leaks.
Brand new stainless dump pipes with seperate wastegate tube plumbed back in. To suit 33gtr but can I can supply them to suit 32. The exhaust gas sensor is a different thread thats all.
Also a really good pfc tune to suit this setup.
I was running stock afms, injectors etc and they have made 292.5rwkw but I had the pfc retuned to a safer more through tune using the injectors and timing maps not just tuning off the afms and it now makes 280rwkw and has seen a little track time with no detination.
If you bought this setup all that would be needed would be a little tidy up of the tune to suit your car. Maybe 1 hours dyno time instead of a full remap. Save big $.
I'm after $1000 for the lot which is cheap considering if your ceramic turbo shits itself an engine rebuild is 5g plus and you also get more power. They are still in the car atm.
Phone if your really interested
Gareth 0417370869
Melbourne
It rises up to 20psi and it drops off to 18psi up top so max about 1.3bar. We couldn't get the boost controller to hold the boost up there but in a way it reduces the chance of killing an engine at the higher rpms so its not really a problem.
These turbos have really good response on the track and at motocarna's so it gives the car really good traction/drive out of corners compared to a few cars running singles and there also nice on the street.
If your after really cheap power you can't go past this setup. Its kept me more than happy for the last few years.
I don't know about when they start making boost and full boost but I can tell you that it makes full boost way before a gtr with a to4z due to how it pulls away out of corners and when it was overlapped over a gtr with 2560-5 turbos with around 10rwkw more power the power curves were almost identical apart from the 2560-5's making about 5-10rwkw more once the power graph began to rise.
Hope this answered your question in a round about way. There is no problem with response. Its all about your right foot and how good you are. What are you planning on using the car for? I have used it for track and motocarna and have had performed very well with what I have and have had no problems with lag at any time.
Must go. any offers
hey mate,
i am running a stock R32 GTR, was thinking about upgrading the stock ceramic turbos.
what mods did you have when you got 280rwkw?
i am only looking at replacing the turbos and getting a FMIC and Power FC i dont want to have to change internals.
Brezza you already have a fmic and its good for over 350rwkw so keep it. Save the cash for an exhaust system and cam gears and the pfc and you have the same mods as my car. Replacing the ceramics is a great idea. I've had a exhaust wheel go through a rb26 and its not cheap to repair in a old car. As for internals there are guys in the club running 350rwkw out of rb26's with stock internals so the N1's will be fine.
hey mate,
is the N1 just a rebuilt stock turbo with better bearings and steel wheels?
also what boost were you running to get 280kw?
i would be aiming for around 260kw, something a little more safer and something i can use without stopping for fuel all the time
Brez
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
