r32 gtr hard pipe from plenum to inner guard replaces rubber ugly pipe
reason for selling: upgrding to hypertune plenum and 100mm throttle body so not needed any more
$110 + del
pm if interested
back up for sale
Edited by NIZ-26T
https://www.sau.com.au/forums/topic/190083-sold/
