  • Replies 60
Posted Images
thanks mate
well i found out that it still running standard fuel system, no cam gears, no aftermarket ecu, also running rb20 airflow meter, no aftermarket coil packs and its runnin a stock auto.
car has never been dyno tuned so this car has so much potential.
ben at rotary motorsports said with all this done and a few hours on the dyno it will pull 300kw easy.
well didnt you rebuild this....so wouldnt you have known before.
no mate car was built by previous owner only reason i found out what car has got was by gettin it dynoed and ringing boostedxtremes and findin out what had been done thats who told me that it would make 300kw as it was but he was wrong.
will u consider a swap? highly modified vl turbo with rb25det motor and gearbox and everything u can think if fresh out of the shop. say hi to brad for me :D
hey guys just put new windscreen in car, new rear tryes 255/45r/17s, got screamer pipe plubed in also had front bar repaired and got wrc for car so puttin price up to $12000
Edited by DRR33
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
