Just to remind you we are all in australia and newzealand, maybe 1 or 2 in japan
i think it would cost thousands to send an engine to siberia
you may be better off looking in a euro forum.
or take your L20et to a very good engine builder and get everything balanced and rebuilt, then add some 1984 300zx turbo injectors and a better turbo from a RB20det
you will have upwards of 115 to 120kW then!
https://www.sau.com.au/forums/topic/190728-barter/#findComment-3435594
Sorry for bad english guys, i`m want get a manual for L20ET.
But i`m changed my mind. Now i`m want adapt a Honda C32A Engine ECU for work with my L20ET
L20ET fireibg order: 1-5-3-6-2-4 Honda fireing order is: 1-4-2-5-3-6. I`m must replace wires for spark plugs and injectors for right fireing order and adapt MAP and crankshaft position sensor, TPS sensor, intake air temperature and water sensors.
L20ET with Map must be a fun :D:P
P.S. :( Hondas ECU`s will be chipped very good and not dificult.
Excuse me for bad english.
https://www.sau.com.au/forums/topic/190728-barter/#findComment-3436662
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
