2a_title.gifspacer.gif■Main Specificationsspacer.gifSpecifications4WDVR38DETTGT-R / GT-R Black edition / GT-R Premium edition•MODELNissan CBA-R35•TRANSMISSION TYPEGR6 Dual Clutch Transmission••DIMENSIONSOverall lengthmm 4655Overall widthmm 1895Overall heightmm 1370Interior dimensions (length x width x height)mm 1750×1475×1095Wheelbasemm 2780Tread Front / Backmm 1590/1600Min. ground clearancemm 110•WEIGHT/CAPACITYCurb weightkg 1740(*1)Seating capacitypersons4(2+2)Gross Vehicle Weightkg 1960(*1)•PERFORMANCEMin. turning radius (curb to curb)m 5.7Fuel consumption rate10-15mode (MLIT screening value)km/L8.2Main Emission Control SystemVariable valve timing•OTHERSDrive system4WDSteeringElectronic controlled power-assist rack and pinionSuspension Front/BackIndependent double wishbone suspension / Independent multi-link suspensionBraking System Front/BackVentilated brake disc / Ventilated brake discTire Size Front/Back255/40ZRF20 97Y / 285/35ZRF20 100Yspacer.gif(*1)When SRS Curtain Airbag System, SRS Side Airbag System for Driver and Front Passenger is installed, curb weight is 1750kg, gross vehicle weight is 1970kg.
•The fuel consumption rate calculated under the given test conditions. The actual fuel consumption rate may differ depending on the condition of the weather, roads, vehicle, driving, maintenance, etc. it is driven under.
•The mode of fuel consumption rates indicated in this specification sheet are all 10-15 mode.spacer.gifspacer.gif■Engine Main Specificationsspacer.gif■Gear Ratio/ Final Drive Ratiospacer.gifModelVR38DETTNo. of cylinders, configurationDOHC/V6Cylinder bore x strokemm95.5x88.4DisplacementL3.799Compression ratio9.0Max. power outputkW(PS)/rpm353(480)/6400Max. torqueNm(kgm)/rpm588(60)/3200-5200Fuel supplyNISSAN EGI (ECCS)
Electronic controlled fuel injection system Recommended fuel/Fuel tank capacityLUnleaded premium gasoline/71 Transmission typeGR6 Dual Clutch TransmissionEngineVR38DETTGear ratio 1st4.056Gear ratio 2nd2.301Gear ratio 3rd1.595Gear ratio 4th1.248Gear ratio 5th1.001Gear ratio 6th0.796Gear ratio Reverse3.383Final drive ratio3.700spacer.gifPlease use the fuel listed as the 'Recommended Fuel' for this vehicle. The use of other fuel types may lead to vehicle trouble or failure. Please note, any trouble or failure caused by the use of other fuel types, will not guaranteed free of charge.spacer.gif•The engine power output values indicated in this catalog are all net power output values.
•Engine power output can be indicated as 'Net power output' or 'Gross power output'. 'Gross' values are estimations of power output of the engine alone. 'Net' values are estimations of when the engine is assembled onto the vehicle. For estimations of the same gasoline engines, 'Net' values are approximately 15% lower than 'Gross' values according to JAMA research.
•Please use unleaded premium gasoline for this vehicle. If unleaded premium gasoline is inaccessible, regular gasoline can also be used, although it may lead to engine power output reduction.
<SI unit conversion value> The unit conversion for converting conventional power output unit 「PS」 and unit for engine torque 「kgm」 to SI unit is as follows. The value is indicated only as and rounded off to the nearest whole number.
1PS=0.7355kW 1kgm=9.80665Nm
Not sure why it did not copy properly but read the comments regarding net and gross power.
http://press.nissan-global.com/PRESSKIT/NI...LISH/index.html
https://www.sau.com.au/forums/topic/191097-353awkw/
I understand that to mean 353KW at the engine, but once the engine is installed in the car. So its still an at-the-engine figure, but the its not just the engine sitting on an engine dyno.
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3439329
  • 4 weeks later...
"gross vehicle weight is 1970kg."
thats my ONLY Criticism with the car. value for money, performance etc - all amazing..but i dont see how this could be flung around a track at a car that weighs more than an AUdi A8....
sure its fast..but imagine how much faster it would be if it were 1400 - 1500kg...it would slay pretty much everything...
even with a "lightweight" version the max they are going to take off it is 100kg (see Superleggera and Scuderia F430 weight reduction)...its still not that much...
it depends..if its a GT Cruiser, that weight is fine...but i dont see many GT Cruisers with engines this small...
still..its getting the numbers...but the weight thing is the only thing bugging me about this car..
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3489447
I'm sure you don't understand 'gross weight' means. :)
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3491475
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
