2a_title.gifspacer.gif■Main Specificationsspacer.gifSpecifications4WDVR38DETTGT-R / GT-R Black edition / GT-R Premium edition•MODELNissan CBA-R35•TRANSMISSION TYPEGR6 Dual Clutch Transmission••DIMENSIONSOverall lengthmm 4655Overall widthmm 1895Overall heightmm 1370Interior dimensions (length x width x height)mm 1750×1475×1095Wheelbasemm 2780Tread Front / Backmm 1590/1600Min. ground clearancemm 110•WEIGHT/CAPACITYCurb weightkg 1740(*1)Seating capacitypersons4(2+2)Gross Vehicle Weightkg 1960(*1)•PERFORMANCEMin. turning radius (curb to curb)m 5.7Fuel consumption rate10-15mode (MLIT screening value)km/L8.2Main Emission Control SystemVariable valve timing•OTHERSDrive system4WDSteeringElectronic controlled power-assist rack and pinionSuspension Front/BackIndependent double wishbone suspension / Independent multi-link suspensionBraking System Front/BackVentilated brake disc / Ventilated brake discTire Size Front/Back255/40ZRF20 97Y / 285/35ZRF20 100Yspacer.gif(*1)When SRS Curtain Airbag System, SRS Side Airbag System for Driver and Front Passenger is installed, curb weight is 1750kg, gross vehicle weight is 1970kg.
•The fuel consumption rate calculated under the given test conditions. The actual fuel consumption rate may differ depending on the condition of the weather, roads, vehicle, driving, maintenance, etc. it is driven under.
•The mode of fuel consumption rates indicated in this specification sheet are all 10-15 mode.spacer.gifspacer.gif■Engine Main Specificationsspacer.gif■Gear Ratio/ Final Drive Ratiospacer.gifModelVR38DETTNo. of cylinders, configurationDOHC/V6Cylinder bore x strokemm95.5x88.4DisplacementL3.799Compression ratio9.0Max. power outputkW(PS)/rpm353(480)/6400Max. torqueNm(kgm)/rpm588(60)/3200-5200Fuel supplyNISSAN EGI (ECCS)
Electronic controlled fuel injection system Recommended fuel/Fuel tank capacityLUnleaded premium gasoline/71 Transmission typeGR6 Dual Clutch TransmissionEngineVR38DETTGear ratio 1st4.056Gear ratio 2nd2.301Gear ratio 3rd1.595Gear ratio 4th1.248Gear ratio 5th1.001Gear ratio 6th0.796Gear ratio Reverse3.383Final drive ratio3.700spacer.gifPlease use the fuel listed as the 'Recommended Fuel' for this vehicle. The use of other fuel types may lead to vehicle trouble or failure. Please note, any trouble or failure caused by the use of other fuel types, will not guaranteed free of charge.spacer.gif•The engine power output values indicated in this catalog are all net power output values.
•Engine power output can be indicated as 'Net power output' or 'Gross power output'. 'Gross' values are estimations of power output of the engine alone. 'Net' values are estimations of when the engine is assembled onto the vehicle. For estimations of the same gasoline engines, 'Net' values are approximately 15% lower than 'Gross' values according to JAMA research.
•Please use unleaded premium gasoline for this vehicle. If unleaded premium gasoline is inaccessible, regular gasoline can also be used, although it may lead to engine power output reduction.
<SI unit conversion value> The unit conversion for converting conventional power output unit 「PS」 and unit for engine torque 「kgm」 to SI unit is as follows. The value is indicated only as and rounded off to the nearest whole number.
1PS=0.7355kW 1kgm=9.80665Nm
Not sure why it did not copy properly but read the comments regarding net and gross power.
http://press.nissan-global.com/PRESSKIT/NI...LISH/index.html
https://www.sau.com.au/forums/topic/191097-353awkw/
I understand that to mean 353KW at the engine, but once the engine is installed in the car. So its still an at-the-engine figure, but the its not just the engine sitting on an engine dyno.
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3439329
  • 4 weeks later...
"gross vehicle weight is 1970kg."
thats my ONLY Criticism with the car. value for money, performance etc - all amazing..but i dont see how this could be flung around a track at a car that weighs more than an AUdi A8....
sure its fast..but imagine how much faster it would be if it were 1400 - 1500kg...it would slay pretty much everything...
even with a "lightweight" version the max they are going to take off it is 100kg (see Superleggera and Scuderia F430 weight reduction)...its still not that much...
it depends..if its a GT Cruiser, that weight is fine...but i dont see many GT Cruisers with engines this small...
still..its getting the numbers...but the weight thing is the only thing bugging me about this car..
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3489447
I'm sure you don't understand 'gross weight' means. :)
https://www.sau.com.au/forums/topic/191097-353awkw/#findComment-3491475
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
