Hey Bugs
Long Time no see
Cant see myself sellin the Skyline in any hurry :D The Vette'll go 1st :)
I got too busy to keep up with NZ forums but glad I found this one - nice local stuff too.
Hopefully cya on a cruise soon
(Weren't you heading interstate?)
Paul
https://www.sau.com.au/forums/topic/1912-insurance/page/2/#findComment-46526
  • 1 month later...
Hey all,
This post would be a bit late. My R33 GTS25T 4door is insured with Just Cars for $990.00 rating 1 with wife as youngest driver, I'm a senior at 48.
:eek: Yes, Metway quotes are out of their mind, off the planet????!!!!!!!:eek:
I am reading this post in my search for info on MOTEC, will be having Tilbrook to install it at a later date.:burnout:
Graham
https://www.sau.com.au/forums/topic/1912-insurance/page/2/#findComment-70649
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
