Make:1994 R33 gtst
Milage: just clicked over 110,000km
Colour:white black bonnet
RWC supplied?upon sale
Currently registered?yes just renewed rego so has 6 months left
Price:$17,000 ono >>> $15,000 FIRM
Contact: pm me or on 0438774173
Comments / Modifications:
Car previously made 257rwhp on 13.5psi and was standard apart from the pfc, cooler and exhaust
Standard rb25det
Greddy copy inlet manifold (standard throttle body)
Hybrid style FMIC
Custom stainless piping
Manual boost controller
Greddy type-s bov (plumbed back to keep it legal)
KKR430 (430hp turbo) 10psi now
s15 injectors 480cc
Modified standard fpr
r33 gtr fuel pump came off a car with 40,000km
Power fc (no hand controller)
Q45 afm
Blitz pod filter
Stainless dump pipe
3.5" cat back exhaust
Heavy duty 5 puk clutch not even 6 months old
Street tuned hasn't seen the dyno yet but very confiedent that it will produce over 300rwhp :rolleyes:
Timing belt changed at 69,000km
Interior:
Standard interior
Silver Auto metre boost guage
Greddy turbo timer
New gear and handbrake boots
harness mounts on parcel shelf (removable)
Audio:
Kenwood double din with frequency enhancer
jbl splits up front
clarion splits rear
Body:
Full M-Sport kit
Black bonnet with vent moulded in (is cracking but will be fitted with a fibre glass one if needed)
Drift wing
18x8.5 fronts and 18x9.5 rears with 90% tread
tein coil overs
Images:
will be posted engine bay pics tonight
Edited by johnbarry88
https://www.sau.com.au/forums/topic/191224-eoi-r33-gtst-jdm-styling/
