hey, the other day i notice my inter. light stayed on while driving, i check wen i stoped an all doors, boot, bonnet wer close...
wat the hell?
i tht i was the passenger side door close/open sensor thingo,
so i un-screwed it, and yeah it was still connected and looked fine..
any ideas wer to start?
https://www.sau.com.au/forums/topic/191373-r33-inter-light-staying-on/
Did you check to see if someone has switched the light to "on at all times" rather than "on when doors are open" :D
na, i check that..lol
now the switch is off..
but wen set to turn wen doors open, the light will stay on evan wen everything is close, plus the door light on the dash stays on too!!
so pretty much every time i drive now the dash door light is on...
i no..lol
its got one wire coming out of the door switch..i think it was just red..
it was stil plug in and looked fine..from wat i can..is there a door module, or something lik that in r33's???
my alarm is connect the the interior light..could it be a short, or a lose wire??
i gota look from my alarm mod. and wer those wires connect to..
sounds very much like a door switch issue
check both of them
when they are open they complete the circuit by using the body of the car for the earth
it could also be in the light assembly
its hard to diagnose it with out looking at the car
but its not a real complex system so just go through it slowly and you'll find it eventually
still on..cant seem to find my alarm wiring harness..
i no its connected to the door sensor switch..
coz wen i un-armd the alarm..for the 30 secs the interior light comes on..
den after 30 secs..it switch off..and the imbolizr..turns back on too..
so i think its shorting out der wer the ..
lose wire or something..
anyone ever had problem with the door switch before?
or got an idea wer to start lookin for this wiring?
i think the problem has somethin to do wit my boot light!!!!
would that keep the door light on???
becoz, i was drivin last nit, wen i notice a bit light comin out of my boot, coz i could c light coming from the air vents, that go into the boot, under the rear window..
so i had to take the bulb out to turn it off..
any ideas..
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
