ok i had the misfiring problema nd it was fixed with regapping sparkies to 0.8mm... but now its missing still but only when the ambient temperature is really low (ie. at night.. like tonight) ios this still the sparkies or coiul packs or just i have to accept i cannot go hard on real cold nights ? i thought the colder the better ? hmm
im getting a powerfc etc done soon will they have tp check all of this out anywyas ? coz im going back to stock boost etc tomorrow until i get he pwoerfc shoujld i just wait until then and get everything setup perfect ?
https://www.sau.com.au/forums/topic/19139-missing-on-cold-nights/
i had that problem, thought it was a miss. What was happening was that on colder nights the boost creeps just enough higher to hit the factory boost cut, and id get a couple of pops while revving it out. as soon as the day got warmer it disappeard. On cold nights i just turned to boost down a touch and it was fine. Now i have PFC and no longer a prob.
what boost are you running? this is probably your problem.
PS- DJ, your car looks f'in sick! what bar you got on the front? cant really see from the pic. And what are those wheels?
ONLY RUNNING 10PSI lol
uh the wheels are some jap ones with carbon fibre coating :D and the front bar is a 'modded' standard mspec one with a huge mouth for my huge cooler lol as in the attachment
*sigh* i guess ill just wait until i get a powerfc :) should only be acouple weeks max
Its typical for an engine to run leaner on cold nights, as the air is denser. But one great thing with modern ecu's, they have temp sensors which are supposed to adjust the fuel accordingly. This probably doesnt relate to you car but i remember reading in zoom that anything like an intercooler could upset the AFM.
The main reason why our old carbie-fed cars did not run well in cold weather even with the choke on is because there is not enough energy in the spark to ignite the fuel mixture.
This can be directly because the ignition coil wasn't up to the task, or more commonly, because the carbie is not atomising the fuel enough. ie, cold fuel clumped together is much harder to burn than a fine mist of warm fuel. So you could fix it by either cleaning or re-jetting your carbie for better atomisation, or getting yourself a higher energy ignition system.
Try cleaning your injectors and checking your spark voltage. I'm not sure how you'd do the latter, so start with some injector cleaner in the tank and see what happens.
Also maybe check your TPS, it could be a mixture issue.
Originally posted by SLY33
looks neat, do you ever get done for no front number plate?
not yet.. only been off for about a week.. i ordered a really small one to be mount4ed to the side and i cbf putting the large one on temporarily :) ill just say its stolen :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
