hey i have a toshiba A200/G01 laptop!
BRAND NEW!! box has been opened to check it and put back!
RRP on these are still selling for $1999.99
FEATURES SPECIFICATIONS
CPU TYPE Intel Core 2 Duo Processor 64-Bit, L 2mb Cache
MEMORY (STANDARD/MAX) 2GB (1GB+1GB) DDR2 667MHz
VIDEO CARD TYPE ATI Mobility Radeon 256MB Dedicated graphics, Maximum Graphics with HeyperMemory is 1023MB
OPTICAL DRIVE Built-In Super Multi Double layer Drive (DVD+R DLx2.4, DVD-RAMx3, DVD±Rx8, DVD±RWx4)
DISPLAY SIZE/RESOLUTION Stunning 15.4" TruBrite™ Clear Super View widescreen (XGA+) 1280 x 800
SOUND/SPEAKERS Premium Harmon Kardon Speakers
VOLUME CONTROL, HEADPHONE, MICROPHONE Volume Control Dial, Headphone port, external microphone port, integrated microphone,
MODEM International 56k V92 Data/Fax modem
NETWORKING LAN 10/100 Base TX, Wireless LAN 802.11 a/g/n
TYPE OF PORTS 1x Express Card slot, 4 x Hi-Speed USB 2.0, 1 SVGA, 1 Firewire, 1 HDMI, 1 TV-Out (S-Video) 5 in 1 Card Reader, Bluetooth 2.0
PORT REPLICATOR FACILITY Cybershop Recommends Belkin Express Dock
BATTERY TYPE/USAGE Approx up to 3 hours* (6 cell) usage maximum
OPERATING SYSTEM Microsoft Windows Vista Home Premium (No Recovery Disc)
ADDITIONAL SOFTWARE Toshiba user’s manual, Toshiba value added package, Norton Internet Security™ 2007 (90day trial), Ulead® DVD MovieWriter® for Toshiba. No Windows Recovery Disc included - make your own
ADDITIONAL FEATURES FingerPrint Biometric Reader, Card reader - XD, Memory Stick, SD , Remote Control
DIMENSIONS & WEIGHT 360 x 267 x 29.8(front)/36.8(rear) mm, 2.7KG
WARRANTY 1 Year Parts and Labour International Warranty with FREE Courier Pickup in Australia*
looking for $1600!
as i said BRAND NEW!!!
FREE postage..
contact me via pm or quicker by phone or email
[email protected] or 0433290801
cheers adrian
https://www.sau.com.au/forums/topic/191613-toshiba-laptop/
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
