Cruse This Weekend From Gawler To Via Adelaide Then To M Bridge
hey guys just wanted to know if any body wanted to go for a cruse this weekend we will head out from gawler to adelaide then to m bridge then where ever havent made a time yet just wanted to see if any body was interested and it should be raining this weekend should be fun :) if youre interested just let me know cheers
spelling 'cruise' properly will add legitimacy to your thread.
also, despite how 'fun' cruising in the wet must be, most would avoid it.
this aint no spelling bee contest i just wanted to know if any body wanted to go for a cruise if they cant figure out what im trying to say stuff them and i only wanted to know people that wanted to go not people who want to bitch about it
ease up princess.
perhaps your poor spelling was irrelevant, but it was so damn obvious...
also, my point was perfectly valid, i wasnt attempting to discourage people from going on your cruise, i was however trying to give you a hand for the next time you get a 'cruse' set up.
cruising in the rain is a widely recognised no-no. grip goes out the window, braking distance increases, all the bad variables, get worse, this normally ends up with a damaged car or worse.
next time, pick a warm, dry day, well, wouldnt even need to be a warm day, just pick a dry a one, put a bit of thought into it, and then post. that way you dont have assholes like me picking your post apart :ermm:
ease up princess.
next time, pick a warm, dry day, well, wouldnt even need to be a warm day, just pick a dry a one, put a bit of thought into it, and then post. that way you dont have assholes like me picking your post apart :dry:
lol - how many times did you check your spelling and grammer on that post before adding it :P I agree tho. Rain = bad.
lol - how many times did you check your spelling and grammer on that post before adding it :) I agree tho. Rain = bad.
dictionary.com does the job lol
im sure he didnt plan it to cruise on a wet day...besides, some of us have AWD :w00t:
November rain is so random, i just did some gardening so its all good
leave the poor dude alone his just wondering who wants to go for a drive, im sure he couldnt plan the rain, and stop bitching about it if you dont wanna go simple then dont f**king go
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
