damn, was driving down the south eastern freeway on the way to work and some damn truck infront of me without covering its load flew a 1cm stone right on my windscreen.
Now my front windscreen is cracked :rolleyes::);)
Does anyone know a place in the south eastern subbie who can fix chip and crack windscreens? if so how much does it cost to fix a 1cm x 1cm crack?
Cheers All..
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/
windscreen o brien does car glasses too... I found that day-to-day private glass repairmen do a good job too in patching up stuff. If you want the whole thing replaced then go to a big franchise.
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-403871
no **** u go to whittlesea glass and mirrors in epping they are the best and that guy who cuts glass is pretty sexy :)
go windscreen obriens people have said good things about them they do quick jobs at a place u choose etc.
but to see me cutting glass in my hard yakka come to whittlesea glass, we dont do windscreens but hey, im there :D
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-403896
narkeh, can you panel beating bro in law/cuz whoever take out a couple of pin dents in my fender / door?
One of my mates backed into my door, took off all the polish and left his blue paint on the car, as well as a pin dent.
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-404112
Cheers All..
Pushead... a truckie blew it's load all over you?
haha... bet that's not the first time.:shake:
https://www.sau.com.au/forums/topic/19186-trucks-and-stones/#findComment-404303
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
