pics are here
also has a shimmed diff
and some blue headlights or something
i need cash atm, so someone with a rego'd rolling 180sx shell or skyline shell would be perfect, so i get some cash and the shell
or a partly completed project car
THanks guys
Edited by lachy 180sx
https://www.sau.com.au/forums/topic/191913-sold/#findComment-3451785
  • 4 weeks later...
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
