  • Replies 142
Posted Images
This still going Eug?
I wanna close off if possible, and dont have time to scan 7 pages to find out where its all at
Cheers
So far still going, think where at 8 people, hopefully can scrape a few more guys together other wise may as well close it off.
Cheers James
possibly down for a set. will confirm v. shortly.
what price am I looking at for a high-flow 2.5" cat? rough price on install?
you can pick up at high flow cat for approximately $100, install i wouldn't know not a hard a hard job tho.
Needs to be fabricated to....
yes, they keep a few in stock but for large orders they need to fabricate.
Cheers
this is actually an old thread from last year, we've just used this one instead of making a new one. as a lot of the older information is still quite relevant.
with the addition of 4 door love we have 7 people, another 3 more would be good and we can go ahead.
Got my extractors at work today ... nice and orange lol
Just a quick heads up to people ...
I asked for a 2.5" oulet and they sent me a set of extractors with a 2" outlet ...
dunno why or what I can do about it ? I thought they only came in 2.25 or 2.5 inch not 2 inch ... I measured up with vernier calipers and it came out to exactly 2 inch ...
currently have a 2.5" exhaust system ... might have to get the exhaust shop to cut off the rear collector and weld on a 2.5" collector ...
will have to see what the exhaust shop say if they can cut the collector off and make up a 2.5" outlet or not
Edited by hr32gts
Ahh wells ... shit happens I guess ..
I am quite impatient at times and hate waiting for stuff ... when I want something I must have it like yesterday ...
Gonna fit the extractors myself and get the exhaust shop to then cut the collector off and make up a 2.5" collector back to the standard Cat converter then to my 2.5" exhaust ...
Hopefully I notice an improvement in low to mid range performance from what others have said it is noticeable so I will wait and see ...
My mate at the exhaust shop will more than likely want to put a flex joint in where the collector normally is to help with flex of the engine so that the exhaust doesn't crack so I will see what he recommends as he has done a couple performance exhausts for me in the past and has always put a flex joint in this position...
... Hope your group buy goes well :D
P.S - The extractors are nice and Orange :P
Quick heads up for people ...
These extractors are not just a quick bolt on job ... where they weld the pipes onto the header plate the welds are too large to put the spacers on so that you can bolt them on properly ... you will either have to die grind the welds down so you can fit the shims or modify the spacers somehow ... I gave my spacers a grind but it isn't good enuf to clear the welds so I will have to pull the extractors off and die grind some of there welds away so that I can tension them up properly ...
But I did notice a bloody huge difference in engine responsiveness and more power through the mid to high end range ... gets up to speed alot smoother and pickup is much better ...
You guys will notice the difference in power that's for sure ...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
