Can some one point me in the right direction i have GTR-R32 its running apexi power fc, having problems with the gizzmo ebc it seems to over boost, even when set on the losest setting,can i do away with the gizzmo and set the boost control through the apexi & if so how do i go about it ? I have spent heap of money on tuning but never been happy with results
does anyone here in tassie know of a decent mechanic that knows what hes doing down here?
thanks
Edited by lukearse
https://www.sau.com.au/forums/topic/192528-ebc/
thanks
Have a chat to WogsRus about settings, he runs the Gizmo EBC and from memory had a similar situation...
Your PFC cant act as an EBC so you would either have to do away with the Gizmo and get a new EBC or you could borrow/buy a manual boost control like the Turbotech to double check things (i have one if you want to borrow it)
As for tuning and mechanical work you should talk to Nick & Ben of GT Garage for all your import and PFC tuning needs:
Contact:
Nick - 0407666107 - Tasboost on Ns.com
Ben - 0408782632 - tas_180 on here, NS.com, BC.com
Nick is rated as the best PFC tuner in Tassie and you only have to look at some of their clients cars to see why :happy:
Good luck and hope you sort it out :thumbsup:
https://www.sau.com.au/forums/topic/192528-ebc/#findComment-3459711
  • 1 month later...
Contact:
Nick is rated as the best PFC tuner in Tassie and you only have to look at some of their clients cars to see why :wave:
Good luck and hope you sort it out ;)
thanks for that but they never seem to answer thier phone is there another number nic give me his address in forrest rd but iv lost the house number and since cannot make contact thanks for your help
https://www.sau.com.au/forums/topic/192528-ebc/#findComment-3530966
hay mate the ebc is a sinche to tune, we need to meet up one day, but the common problem is that the actual wastgate can not flow enough exhaust through it if you have a nice free flowing exhaust.
Anyway we need to catch up and i'll give you the run down.
https://www.sau.com.au/forums/topic/192528-ebc/#findComment-3531266
ok thanks that would be good what paart of hobart you live ?
https://www.sau.com.au/forums/topic/192528-ebc/#findComment-3538159
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
