These wheels will only fit a GTT with a 5mm spacer on the rear. no guard rolling however and sit perfectly when dropped :ph34r: wont fit a 33 gtst either .. again spacers
I'd buy them and spray them black but im strapped for cash :rofl:
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490234
Well I have the exact same wheels ( wide pack ) fitted on my R34 GTV ( turbo brakes & suspension factory fitted ) with NO spacers anywhere. So, unless there is a difference between mine and a GTT they should fit. I'll admit that the gap between the rear calipers and the wheels is small, but it doesn't touch :wave:
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490429
I had these wheels also on my r33 gtst. and i didnt use any spacers or anything and it filled the gaurds perfectly. not sure where u got ur spacers ideas from DECIM8? but yes the brakes only just fit behind the wheels which sucks. good luck with the sale.
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490791
Sorry should of specified.. Series 1 33 it will fit.. series 2 it wont due to bigger nissan writing. R34 GTT will not fit them, Gtv may I have no idea .. GT will.
more power bigger brakes..
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3491029
Does anyone have a pic of white impuls on a gunmetal R32, ive been wanting some in shadow chrome for a while but if it looks decent in white on a gunmetal 32 ill consider these.
I have a set in normal chrome, that pattern looks good on pretty much all R32's
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3492561
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
