Item: BSA AU Racing Series Wheels - 18x7.5 - White
Condition: Brand new in boxes
Price: $450 firm
To Fit: (What car) Most 4 stud cars
Contact: PM me or email me at [email protected]
Comments: Wheels are brand new in boxes. 4 stud pattern. 8 hole. 100/114.3 PCD. Offset is 43. Colour is white with machined lip.
Wheels were bought nearly 6 months ago and just never got around to putting them on and now i've decided that i'll just buy 17's...
Buyer is to pick up, delivery also available if in Canberra or if interstate a courier can be arranged.
Edited by rasumadu
bro would the fit a front wheel drive
pretty sure they would...i mean my ride is fwd...as long as you got a 4 stud pattern...
ps: to all those who will chop my head off and say that the gts-4 is not fwd..i no! but i don't have that ride anymore...
Edited by rasumadu
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
