It is quite amazing the fat mid range but.
On the dyno loaded up he said the RB30 came on to full boost around 2300rpm however generally on the road it hits full boost at 3000rpm.
Its interesting how the power curve goes flat up the top end.
I'm not sure if that is a good thing or not. Maybe it is as when you click the next gear it will be making basically peak power already 240kw where as on the RB25 it has to build up to that powerlevel from say 200rwkw.
Matthoon also posted his RB30 dyno reading of 320rwkw on 14psi. That is using the RB26DET head or was it just the cams?!?! and doesn't go flat up top.
  • Replies 68
  • 9 months later...
hope this helps
500 horsepower is equivalent to roughly 1.3 billion joules per hour.
1 liters of fuel contains 35 million joules, so a 500-hp engine has to be able to burn just over 37L of gas per hour.
However, car engines are only about one-quarter efficient -- three quarters of the gasoline's energy escapes as heat rather than as power to the wheels. So the engine actually has to be able to burn at least 148L per hour, or 2.4L per minute.
Petrol requires about 14.7 kilograms of air to burn 1 kilogram of gas. Air weighs 1.222 kilograms per cubic meter at sea level. A Litre of gasoline weighs 1.34 kilograms. So the engine has to be able to process 1.34*2.4*14.7 kilograms of air per minute, or roughly 38 cubic meters of air per minute. That's 38,000 liters of air per minute.
If a straight 6 engine is turning at 6,000 rpm, it can inhale a total of 18,000 cylinders' full of air per minute. If it needs to inhale 38,000 liters of air per minute, it works out to roughly 2 liters per cylinder-full. That's a 12-liter engine.
But an engine that size wouldnt be able to turn at 6000 rpm maybe (ok it could but not easily) maybe closer to 4000. soooooo
4000*6/2 is 12000 cylinders per minute. we still require 38000 litres of air for 500hpso
38000/12000 = 3.2 ltrs a cylinder * 6. we now need a 19.2 ltr engine.
but wait theres more...
ok so how do we get 500hp from 2.5/6 litres. the turbo, double the airflow and you can effectively double your fuel.
ok i think thats enough maths forme today... you can add up the rest
What does this prove... its proves that power is more complex than simple litreage.
RPM is relative to cylinder size, air flow to rpm, air flow to fuel consumption.
Hey man just thought id mention at the time of those runs it was a GT30 dash 11 (475hp) turbo, the 25 had no trouble spinning it up. It also was running a .82 a/r housing with a fairly tight nozzle and small turbine wheel. It was a pretty responsive turbo on the 25, on the 30 it was psychotic. I have since upgraded as it was cutting my top end pretty badly.
Joel.
After looking at those two power curves, have to agree the RB30 is going to be heaps stronger at the same maximum boost.
But I suspect though that the same rated boost level was only reached at the very top end with the RB25 combination.
Fitting the RB30 allowed the turbo(s) to come on boost far sooner and create that massive mid range torque.
I would like to bet that some slightly smaller exhaust turbines/housings on the RB25 combination would also have come on boost sooner as well and given a similar if not identical result.
Still, it has ended up a mighty impressive engine though, no matter how he finally did it.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
