skyline
good - a better daily driven car, more comfortable and refinement. better off boost power due to 2.5L and big brakes.
bad - heavy, higher maintenance, had to spend more on mod if u want to go REALLY serious.
180
good - better handling, touch faster, u won't see many around.
bad - noisey, roomy.
i upgrade from silvia to r33 as i think silvia is too small for me(me,gf & sister) and it's damn noisey, not good for daily driving.
but as my gf & sister got the own car now, i would like to go back to silvia(S15) as it's cheap to reach my aim of performance(low 12sec car)
Originally posted by strange
hi guys, considering whether to buy a strawberry face 180 or Skyline R33 GTSt series II, but can't really decide, somebody explain the pros and cons of these 2 in your own opinion? Thanks in advanced..
Cheers!
And you are on a Skyline forum asking this ??
Cheers
Ken
I used to have a strawberry face... jus the look on ppls faces when you tell em its a harchback 200sx is enuff in itself.
R33's are as common as camries, get sumfin different. I got my CA18DET 180 for $13k (like 3 yrs ago) and then got a bomex kit from japan for about 4k (from a wrecker) bit of patch up etc shipping and for around 19k I was pushin a pimped up car.
As far as pros n cons, the GTSt is more up to date, seriousy the interior of a 180 sux dogs bollox, so uncomfortable, the seats are shit (had fake recaro's in mine but i'm talkin bout the stock ones). All the controls are on stalks like really old outdated 1988 cars (even the R32 din have them).
So yeah, if you're after creature comforts get an R33 its the biggest whale... i mean car as far as 2 door under 1.3tonne imports go. :)
If you're more of a mods person, get an latemodel 180sx with a black top SR20DET in it, it'll give you the most bang for buck... more than an R33. it really responds well to mods as well. I pulled 160rwkw out of my 1.8L, so meh.
Originally posted by Maxx
skyline
180
thanks for the info dude.. :(
So yeah, if you're after creature comforts get an R33 its the biggest whale... i mean car as far as 2 door under 1.3tonne imports go. :D
the bomex kits are really nice... and ya, the interior for 180s really sxxk big time.. :(:D:mad: :mad: :mad:
BTW, i found my bomex kit at a wrecker on a strawberry face silvia that was written off. Pure luck if u ask me. An original bomex will cost ya about 9grand.
You can get fibreglass copies n aus now tho for about 4k-5k, with all the ichi-go kits (strawberry faces) that come down here. I know Skyline Imports in Adelaide got one about a month before I got mine back then, I'm sure they still have the moulds.
awesome! are there many of these around? or would u have to do the conversion urself and or import one?? that sounds wicked!! im contemplating a new car but i really dont want to sell my baby.
not that i know of, dude.. there's only one in perth that i saw... which is show cased in one of the garages.. i'm not really sure how or whereabouts doing the conversion itself.. but i do know there are people over at japan doing conversions for ichigoes =P
its actually a kit that was made by bomex, but not sold commercially in mass quantities, to keep its uniqueness.
Its basically the next version of the "sileighty" look.
The panels all fit a 180/silvia very snugly... all you need to do is chop a lil bit of the front bar support off (with your friendly angle grinder) and the rest bolts into place.
In the kit you get:
2 front guards that sit on the 180 chassis and flow into the existing doors and a pillar shape.
2 original s15 headlights
1 fibreglass bonnet also in the s15 shape but with a lil bit of bracket and mounting work under to fit the 180 chassis.
The front bar actually comes seperate, but you can source it from them if you want.
i got pics for the install process if u guys want
my local panel beater fixed up the dents in my kit and installed it on my 180 for me. Mine was like the 7th in australia or sumfin. God knows how many there are now with couple of the shops making fibreglass moulds of the original bomex kit.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
