K so i just pulled my radiator off and reverse flushed it, was getting alot of brown water coming out depending on the angle i held it but it eventually cleared up..
The car has been overflowing from the cap for a fair while now (overheated other night to), and so far a gasket test and co2 test show that it's nothing engine related and a new radiator cap and overflow hose didn't help.
I thought the radiator might be blocked, so i ran the hose thru and the flow was fine.. So tomorrow i will reverse flush the engine in the same way.
Now i have 2 questions:
1) does anyone with a gtr know whether i'll have to remove the water pump & intake manifold to get to the thermostat? Theres not enough room to move anything, and the workshop manual only has info on testing it not removing it for some reason?? Pictures are at the bottom of this page
2) I've noticed the lil hose thing on my car is pinched in 2 places, first pinch is about a 40% pinch (40% obstruction) and 2nd about a 20% pinch, i've enclosed pics but was just wondering if this pinching was likely to be what is causing pressure to build up and over flow the radiator? If not, should i replace it anyway (it's pretty much off)
Thanks in advance peeps
Have also put a pic of the brown stuff in the radiator (which seems to be rust, but makes no sense as the last owner definitely ran coolant and the radiator is brand spankers)
Edited by GTAAAH
I had a similar problem with my 33, even went as far as getting head pressure tested, put it all back together and it still done it. Took thermostat out, got a mirror and looked in through thermostat housing to find that my water pump had NO blades left, had all rusted off.
oO ouch!
Did you have some circulation still? my water level increases slightly as the engine rev's increase (wasn't sure if this was pressure/heat related or because the water pump was spinning faster)
I'll whip the thermostat off and try see the pump, dad thinks it sounds like a fair bet, thanks
Anyone got any idea on whether the pinched steel line would cause me a problem?
Where is the pressure release exactly? (feel free to circle my pic)
thanks
Edited by GTAAAH
K so
2) would the pipe being pinched make any difference to flow etc, i.e. should i worry about it
and
3) where is the thermostat in these things.. some pics enclosed, i'm trying to find it so i can boil and test it, it doesnt seem to be in the same location as the 33 one in pranks guide
Cmonnn sum1 out there has to know the answer to 1 of these >.<
I was thinking it was part of the inlet piping that the radiator was attached to, now i'm thinking it's on the block side of the thing i'm touching with my finger in the 3rd picture.
I will have to remove the inlet manifold to get this off correct?
Edited by GTAAAH
MM ur right i am pretty sure it's what i'm looking for but, does anyone with a gtr know whether i'll have to remove the water pump & intake manifold to get to the thermostat? Theres not enough room to move anything, and the workshop manual only has info on testing it not removing it for some reason
Edited by GTAAAH
OK so on the RB26 u need to remove the inlet manifold piping that comes from the battery tray (the rubber 4" tube) to get at the back bolt, and to remove the top one u need to pull one of the hoses that runs fuel apart and use a ratchet with an attachment that allows u to use it from angles other than straight
huge pain in the ass taking the thermostat out !
The water pump blades i can't see but can feel, they feel perfect so am hoping a new thermostat will fix it, my old thermostat seemed to be jammed half open so i'm not sure (cbf boiling it either, new one was $30)
Anyone got any idea on whether the metal tubing being pinched in post 1 would make a difference to flow, and should i bother fixing it/replacing it?
thanks
Edited by GTAAAH
Flushing your radiator with a garden hose wont' work,
Best to get done by a radiator place.It need to have the top tank remove, cores get clean throughly......etc . My old gtr over heated right on new year's eve coz i got stuck in traffic, checked Thermal Stat, then changed to a new Thermal stat, flush 3, 4 times.
Also skylines radiator is alluminium isn't it?
stock skyline radiators are copper core.
mate you have to earth out the radiator if it is aluminium. not related to your water level though it is related to aluminium radiator corrosion.
good luck with the problem.
- The thermostat is where you are pointing in your last pic I believe
- The pinched pipe your referring to, is the return for the turbos water supply.
Water comes off the line that goes through firewall, then around back of head to the banjo "T" piece. Coolant that doesn’t go down the "T" piece and through both turbos, back towards the block, goes around the front of the motor and connects to that alloy piece (where top radiator hose connects)
The idea, I would think (putting my mind into that of a Nissan engineer) is that it feeds the turbos with close to constant engine temp coolant, because it effectively is always flowing past the banjo "T" piece. This is unlike if you had a pipe going from cool side of radiator to the turbo, as water would head up in the line (close to exhaust manifold) before going through turbo.
Its very very unlikely its causing your cooling issues, it might just up the temp of the water feed to the turbos (as the kink is reducing flow through the pipes (that are very close to manifold)
Cheer'oss
PS: The engine is brown in my paint shop pic, just like your motor ha :no:
Cheer'oss
PS: The engine is brown in my paint shop pic, just like your motor ha ;)
TURNS out after all that, that the thread for the cap to go on, on top of the radiator was slightly bent, letting the water seep out, 2 taps with a hammer and hasn't leaked since, ._.
Edited by GTAAAH
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
