Hey guys, well as the title says my twin plate clutch crapped itself last nyte, it was starting to go a little while ago but last night it went and now it just slips like mad....
Now i can either buy a new twin plate or get it re built... my question is, has anyone on here re built their clutch before if so was it expensive and where did ya get it done. im unsure what brand it is as it came with the car....
So buy a new clutch or rebuild???? any advise or past experiences would be great
cheers mike.
https://www.sau.com.au/forums/topic/194056-help-a-brother-out/
not sure but michael at autobarn mile end could give you a good price on a new one just tell him i sent you cause i dont work there any more and they having a sale on all performance this weekend including things that need ordering in
i rebuilt my old clutch its alot cheaper and good way to go. go to acs
where did ya get it done?? did they do a good job.. im looking at getting a rebuild seeing as it's already a twin plate and would like to save myself some cash by getting it re built
Hey bud, We can get you NISMO and Xtreme at a good price if you decide not to rebuild.
Ryan
thanks bro, im just getting some info on whats better to do before i decide.... will let ya know
i went to adelaide clutch service, they dont fit clutches but i just left my car there and they took it down the road for me to fit it, really good job, best clutch ive driven so far. it cost me 800 to rebuild, he said it was a really tuff clutch.
+1 For ACS.
They are the makers of extreme clutches and they products are brilliant. They sponsor our race car and the clutch they provided was to good; started doing diffs once it was installed.
Edited by D_stirls
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
