I recenetly installed a new sound system into my r33 and have got an issue:
basically the headunit has 2x preouts, and ive run two sets of rca leads from my headunit to the amp in the boot, , now if i plug in only one set of rca leads into either the headunit or the amp, the static noise is fine, and everything is ok. But if i plug in both sets of pre outs, the static noise is much more apparent, and once the car is turned on, this little hum turns into a loud high pitch noise coming from the tweeters from my splits......
what could this problem be?, im getting really frustrated, im thinking either:
a)crossover to tweeters, as its really only the tweeters making the noise (from both splits)
2)need better rca cables, more shielded ones?
also, this sounds gets louder the more i rev the car.....alternotaor whine?
Edited by nsta
had the same problem with mine. sounds like a ground loop problem - headunit and amp are grounded in different parts of the car. you could either run the ground lead from the headunit thru to the amps grounding point or buy some ground loop isolators (much easier option). they plug inline between the rca's and the headunit and cancel out the ground loop. worked a treat on my car. you'll need one for each rca lead and they're usually around $30 each. most car audio places will stock them. i still get a little noise thru my fronts but its only noticable when the volume is turned right down (so not very often)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
