Mate... if you're into clubbing just tell the cabi to take you to surfers on the weekend and im sure you will find something you like.
During the days however if you havent been before it's worth checking out at least one or two theme parks.. id say wet n wild and dream world. Apart from that you have the beautiful burleigh beach...summer sun...girls...waves... is there anything better?
If you wanna go shopping check out either pacific fair or one of the other major shopping malls.
If you get really bored head up to Brisbane for a night or two check out the night life there and anything else they have to offer.
For a tourist there's always something to do down here so im sure you will be busy the whole time.
Anyways, enjoy the Gold Coast ;)
