Item: RB26 Standard Camshafts
Condition: Very good
Price: $150
To Fit: RB26 or RB20det (What car)
Contact: email: [email protected] or PM
Comments: Came out of my RB26 head (R32) its in very good condition. PM me for pix if your interested. I preffer local pick up or i can send interstate on buyers expense.
Cheers
Babak
Edited by MRPREZ
https://www.sau.com.au/forums/topic/194658-rb26-standard-camshaft-sold/
There is a thread in forced induction about fitting GTR cams to an rb20, i would suggest anyone interested in buying these for an rb20 read it first, the conclusion was that a solid lifter conversion was also required to make them work.
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
