I have a Skyline GTR track only vehicle. - Gun Metal Grey
It has the best tyres you can buy on them, 7k worth of suspension - ALL HKS. This vehicle is fully ready for race, roll cage has been taken out along with gauges. (not regoable) - well it is.. i have a complied and registered shell here waiting...
this car is grey.. i will have pics soooooon
Toe in/out bars
Coilovers - Best ones HKS make
Control Arms,
Castor Rods
Cusco Strut braces
Sway bars
Its got a Kakimoto Exhaust on it
HKS oil cooler
HUGE front mount, and i mean its HUGE!!!
5 core fully aluminum radiator, custom built
The beefest HKS clutch package you can get
LE Kakimoto rims - You CANT buy these rims new anymore
Full HKS FMIC kit
The list goes on and on
Asking $9500 ono
needs bonnet and front bar - i can organise that though for little extra
Edited by Rude Carz
https://www.sau.com.au/forums/topic/194823-eoi-gtr-skyline-r32/
located in bris, more than happy to ship/truck it
this car is grey.. i will have pics soon.
car has had most of the dints taken out, still in primer in spots.. can paint it for a little bit of money.
not regoable.. although i do have complied and perfect condition shell here. car is a 93 i believe
COMES WITH A APEXI FC!
APEXI FC AND 700HP fuel pump was paid for today - wil install tomoro night. pump is a genuine Walbro
No expense spared with this
11k with bonnet, bar, tune and paint done
$10. 600 with bonnet bar and paint work done
Shell has a rear quater panel cut out, easy fix
and there is a little dint on the front - minor
this shell has NOT been registered in any way shape or form as written off so it still can be used.
will post pics up and pm you some pics there champion :D
DAAAN
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
