Thought I would drop in an say hi to you all.
I have recently bought a 94 R32 GTR.
I have fitted a front pipe back Kakimoto Exhaust but still running the compliance cat. I want to fit a hi flow cat to it, could anyone out there point me to the right direction to what brand or installer to go to?
Thanks
Dan
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/
yeah...
10,000 reasons having a gutted cat is so cool, by the epa.
has anyone ever actually been slugged that for getting busted?
i dont know anyone that has, its all heresay as far as i know.
regardless, i sure as hell wouldnt risk it.
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3491881
the 10 thousand dollar fine is a myth, my friend actually called up and asked... lol its defectable but what on a import car is not defectable nowadays ahahaHa
i think it may have originated from interstate though, so perhaps they do have some kind of large fine for it?
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3491900
and yet more hearsay.
i heard it from a friend of a friend of mine who is closely related to the prime minister.
its all well and good to believe what you hear an epa/(insert vehicle control related body) call centre monkey tell you until the other one tells you otherwise.
:D
but aside from that, welcome to the club dan.
as i said in my above post, head down to an importer or a wrecker dealing specificially in imports, and pick yourself up a late model gtr cat, or get a metal cat for a few hunge and have that fitted up.
Edited by scandyflick
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3491906
Thanks
Dan
Hi, welcome aboard the SAU train!!
Yeh head down and see Mark at Exhaust Tech on Goodwood Rd, If you've got cash and want a killa job head there!!
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3492041
Wow Deluxe i had to read that twice.... first i thought it said "if you've got cash and want a killa head job there!!"
Welcome Dan.....
Post pics of your ride when you get a chance!
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3492142
another Dan in the club :) and with a GTR 32 :):wave:
nah all good, ive goten used to have the most common name in town as im sure you have also.
edit: just read the post properly, its early maybe i should start drinking coffee in the morns ;)
take the cat out the bag all together ;)
exhaust tech the place to be.
Edited by gzilla
https://www.sau.com.au/forums/topic/194831-hi-all-new-here/#findComment-3492191
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
