If that's your engine bay in your avatar, I'd say you have a fair job ahead of you.
yeah thats my engine bay in my avatar..
does anyone know how i can get a wheel off without the locknut key.. i never recieved one with the car and before i could go get them taken off i got a flate tyre!
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3500295
  • Replies 43
freeze it and chisel it off...... get a socket bit and whack it in until it gets into shape...
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3501766
I was under the impression that changes like that affect emissions, and any emissions change means big issues as you would then be up for emissions testing. Some can correct me if I am wrong. Perhaps ring regency technical enquiry line and ask what are the laws about changing plenum?
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3502823
yeah id say thats about right.
im not sure on the full laws of it though.
is it just an aftermarket plenum with stock runners and forward facing tb?
or is it all aftermarket? cant really tell from your avatar.
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3502884
Why is it that most ppl with skylines are getting defected and they pull me over and say nothing about a defect.. Got pulled over last night, all he did was shine the torch at my tyres, which are almost brand new, and yeah, let me go.. Guess owning an import your bound to get defected sometime...
P.s. I agree, dont drive anywhere near the bay on friday and saturday nights..
Edited by GTR-32
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3503034
does this give you a better view
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3503335
thnx for the help guys concerning the wheels nut. i smahed the crap out of it with a hammer and a 18mm socket abd\\nd as we speak my tyre should be getting fixed...
wat sort of issues would i b facing with my plennum.?
there was easier ways then those 2 but if it works it works :D
also, from the picture youll have to put the standard heat sheild back on over the turbo if it not on there. if you dont have any of these parts just take it through as is and get your list. much eaiser then pissfarting around trying to find bits that they might not even do you for.
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3503458
to reduce getting done for the plenum, would it be worth going and getting the turbo tuned right down along with the fuel ratio/mixture or wat eva u get done lol...
as for weather its got stock runners and wat not i wouldn have a clue sorry.
Edited by Kieran
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3506139
  • 2 months later...
Its a HKS Turbo..
This HKS turbo replaces the stocky in standard position and is internally gated.
The plazmaman plenum pictured uses the stock runners.
Note also the plumb-back BOV, which is legal.
None of this really matters, what matters is:
1) suspension allows underside to be at least 100mm from ground
2) noise at 3000rpm
3) emissions reading from exhaust
I havent been online for a while so I'm probably too late.
The TEIN suspension is fully adjustable and you should be able to adjust the ride high to meet legal requirements. That said, the only thing that was illegal was the exhaust being too loud, just needed a resonator or or something to take the drone out.
Let us know how you went huh?
Edited by Color_Of_Green
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3634354
You cant get a defect for a fmic but most times to fit them you have to cut your frount reo bar and thats a defect but if the cop said nothing about the reo bar then just lay a complant and plz dont be scard of cops they are just lil kids in blue
https://www.sau.com.au/forums/topic/195000-defect/page/2/#findComment-3635181
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
