I've sold my beloved beast so now i need to clear out my garage! I need to get rid of all this stuff. most prices are totally open to offers!
LOCATED IN SYDNEY, NORTHERN BEACHES
will post at buyers expense BUT PLEASE NOTE: anything you want posted i'll have to put another $10 on the price for the time and effort it takes to wrap box and get this shit to the post office. ONLY CAUS THE PRICES ARE ALREADY SO LOW ITS THE ONLY THING THAT MAKES IT WORTH POSTING!!!!!!!!!!!!!!!
PM or call me - 0410 321 343
Cheers,
Row
GTR Style Front Bar:
BRAND NEW STILL IN PLASTIC bought from UAS for $550 (thats the price they are everywhere and then realised my cooler piping was in the way. The image isn't my bar BUT its exactly what mine looks like.
PRICE DROPPED TO $350!!!!! what a discount for something that is BRAND NEW!
PARTS FROM AN ECCS SILVER TOP RB20
Intake Manifold lower half:
Complete, comes with 6 injectors, fuel rail, little JECS controller and stock fuel pressure reg and all other electric gizmos Its in good condition, came from an engine i bought to replace my old one. Perfect for using to design a forward facing manifold for your RB20 while keeping your car on the road. (the top half is gone but this is the only pic i have)
Well cheap at $20!!
Stock exhaust manifold and heat sheild $10:
The manifold is in good condition but the heat shield has a little surface rust on it. Good if you're looking to turn your car back to stock for sale.
Cheap as at $10
Stock sump:
Will fit other RB engines, good to turn 4WD blocks into RWD. needs a clean is all
SOLD
Oil Dip Stick:
good condition $5
Water Pump:
Good condition, came off the doner engine which had around 80thou ks has been sitting around for a while though so needs a clean and an oil. (Cam gears have been sold!)
$10
Air-con condensor pump thing:
Calsonic type with the pully and clutch and little pipes coming out of it (been told these are worth about 100 from wreckers etc)
$20!!
ALSO
Machined Rb26 & Internals
All this stuff was completely machined for a rebuild with forged pistons so its all in very good condition but has been in storage for a while, hence the covering of oil to prevent surface rust, so it needs a clean. The low prices reflect the fact that now without a project to put it all in i want this stuff gone! open to reasonable offers
R32 Block, crank and cradle:
lined bored for this crank and cradle and honed to 87mm, crank machined for rebuild, reground contact surfaces, perfectly straight, all parts crack tested and came up 100% ok, all parts pressure washed - $1500 neg
Rods:
machined for rebuild, all contact surfaces reground, crack tested - 100% good - and pressure washed - $150 neg
for more info & pics pm me or see my other post for 'Machined RB26 block and internals'. selling at a massive loss
Edited by Black Betty
https://www.sau.com.au/forums/topic/195660-delete-me/
  • 4 weeks later...
Has the bar been trial fitted to a GTSt? I need an assurance that it does not require modification to fit a GTSt, otherwise the panel beater is going to charge me uber dollars to cut and modify to suit my car :(
absolutely sure it is made to fit an R32 GTS-t
Bought it from UAS as 'GTR style bar to fit GTS-t'.
https://www.sau.com.au/forums/topic/195660-delete-me/#findComment-3671225
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
