I've sold my beloved beast so now i need to clear out my garage! I need to get rid of all this stuff. most prices are totally open to offers!
LOCATED IN SYDNEY, NORTHERN BEACHES
will post at buyers expense BUT PLEASE NOTE: anything you want posted i'll have to put another $10 on the price for the time and effort it takes to wrap box and get this shit to the post office. ONLY CAUS THE PRICES ARE ALREADY SO LOW ITS THE ONLY THING THAT MAKES IT WORTH POSTING!!!!!!!!!!!!!!!
PM or call me - 0410 321 343
Cheers,
Row
GTR Style Front Bar:
BRAND NEW STILL IN PLASTIC bought from UAS for $550 (thats the price they are everywhere and then realised my cooler piping was in the way. The image isn't my bar BUT its exactly what mine looks like.
PRICE DROPPED TO $350!!!!! what a discount for something that is BRAND NEW!
PARTS FROM AN ECCS SILVER TOP RB20
Intake Manifold lower half:
Complete, comes with 6 injectors, fuel rail, little JECS controller and stock fuel pressure reg and all other electric gizmos Its in good condition, came from an engine i bought to replace my old one. Perfect for using to design a forward facing manifold for your RB20 while keeping your car on the road. (the top half is gone but this is the only pic i have)
Well cheap at $20!!
Stock exhaust manifold and heat sheild $10:
The manifold is in good condition but the heat shield has a little surface rust on it. Good if you're looking to turn your car back to stock for sale.
Cheap as at $10
Stock sump:
Will fit other RB engines, good to turn 4WD blocks into RWD. needs a clean is all
SOLD
Oil Dip Stick:
good condition $5
Water Pump:
Good condition, came off the doner engine which had around 80thou ks has been sitting around for a while though so needs a clean and an oil. (Cam gears have been sold!)
$10
Air-con condensor pump thing:
Calsonic type with the pully and clutch and little pipes coming out of it (been told these are worth about 100 from wreckers etc)
$20!!
ALSO
Machined Rb26 & Internals
All this stuff was completely machined for a rebuild with forged pistons so its all in very good condition but has been in storage for a while, hence the covering of oil to prevent surface rust, so it needs a clean. The low prices reflect the fact that now without a project to put it all in i want this stuff gone! open to reasonable offers
R32 Block, crank and cradle:
lined bored for this crank and cradle and honed to 87mm, crank machined for rebuild, reground contact surfaces, perfectly straight, all parts crack tested and came up 100% ok, all parts pressure washed - $1500 neg
Rods:
machined for rebuild, all contact surfaces reground, crack tested - 100% good - and pressure washed - $150 neg
for more info & pics pm me or see my other post for 'Machined RB26 block and internals'. selling at a massive loss
Edited by Black Betty
https://www.sau.com.au/forums/topic/195660-delete-me/
  • 4 weeks later...
Has the bar been trial fitted to a GTSt? I need an assurance that it does not require modification to fit a GTSt, otherwise the panel beater is going to charge me uber dollars to cut and modify to suit my car :(
absolutely sure it is made to fit an R32 GTS-t
Bought it from UAS as 'GTR style bar to fit GTS-t'.
https://www.sau.com.au/forums/topic/195660-delete-me/#findComment-3671225
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
