ok first of all i kno most people wont understand why i bought it 3 months ago and now im selling but its a genuine sale i just want to move back to a street car now so i need to let this go. ok......
1989 r32 skyline gts-t
SR20 motor ( out of a 2000 model s15 )
5 speed
211kw at the wheels
Apexi power FC computer + hand controller ( tuned at racepace in melbourne )
OS geiken twin plate clutch ( recently rebuilt )
TOMEI 256 cams
550cc injectors
HKS GT SS turbo ( less than 1000ks done )
N/A SR20 throtlle body
Big internal fuel pump
xforce manifold
rb25 airflow meter
GTR exhaust
Big TRUST FMIC
GReddy triple core radiator
KAZZ 2 way diff
HKS coil overs
camber adjustable
hicas lock bar
drift pineapples
SPARCO driver's seat
GTR interior
shift knob
turbo timer
sparco steering wheel
boost gauge
Racing pedals
Strut tower brace
Drift style handbrake
body kit is genuine BN Sport kit
evc 4 set to 1.2 bar
WORK miester 3 peice rims.. fronts 18'' by 10'' and rear 18'' by 11'' new tyres on the rims.. front 255/40 rear 275/40
Full wide kit 30mm rear and 25mm front.
have some shitty skid rims and jap quality 30mm spacers for them
the car is not complied but has all the import approval and everything. i was quoted about 6k to comply it if i did no work on it just gave it to them and got it back. the car is seriously sick ive never owned or known anyone who owns anything like it. turbo is pretty much on boost whenever you mash the throttle, makes 5psi at 1500rpm. ive had it dyno'd twice, one at aussie dyno and made 208 with boost spike and massive dodgey bleeder. after i got elec boost it made 211 with the turbo starting to run out of puff. ive olny taken it to lala once and that was a GRIP day. car went really well.
the only 1 problem is something has f**ked out in the gearbox we think the selector has f**ked up because i only have 1st 2nd 3rd and 4th no 5th or reverse. box feels really good apart from that. im sure its nothing major. my mechanic thinks the same. car lights 1st 2nd and 3rd no dramas but could do with some slightly skinnier tyres on the back for real good fun. i can put anyone who is interested in touch with the guy i bought it off who is also the guy who has done 90% of the work on the car for any more info.
price is $15,500 slightly neg at this stage. im in no hurry to sell what-so-ever so dont bother low balling me. car can be veiwed this weekend all glammed up at the christmas cruise. ill send it anywhere in aus with the buyer paying.
some adjustable arms and you would have a potentially competative car that looks sick and is different. paint is shmick as except for front bar which has a few little spider cracks from the drive back from melb. ok any more info let me know. cheers 0401178091
https://www.sau.com.au/forums/topic/195704-wide-sr-powered-32/
swap for our spare car? perfect sleeper with all the hard suspension work done... this is a wicked hills car.
http://www.skylinesaustralia.com/forums/S1...al-t197167.html
ive wanted this R32 since it landed a fe years back.
no help with the sale but seen this car first hand about 4 months ago and it is one orsome car. its pretty much what a jap biult car should be. this car would have so much potential with the sr20 to be either a grate drift car or an orsome full on track car.
^^ thats coz it is jap built... cheers mate. anyway still for sale. will be sliding on the 6th if no1 shows interest before then.
pics arnt flattering it looks much tougher in real life. paint is near on perfect and whoever did the bodywork did an awesome job. ill even chuck the dvd player back in it for the sale. cheers
Edited by boostd gem
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
