Blitz is some crazy far out design like the uras one.. But look into it cheers man..
To me it looks like the combo of the Stock Altia bar, and a nismo lip extension (factory option) which is basically what I originally wanted.. Then I spotted this.. To bad the bloke is in melb and does not wanna sell it :worship:
Edited by DECIM8
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
