hey guys..
i need a help here :) i just put an r34gtr mfd in my skyline but can't get to this screen or oprate it.
every thing is working but couldnt get this display so far. refr pic..cause i need to get the speedo and taco working..
any one has gtr can help me plzzzzzzzzzz.. or just leave you contact number and i'll be more than happy to call you back ..
cheers. :D
Edited by sun33
https://www.sau.com.au/forums/topic/196266-r34-mfd-heeeeeeeeeelp/
  • 1 month later...
thanks chris,but i have to say that thread tells u nothing...i even get confues after i read it...Ive seen a guy driving a white 2 door GTT with GTR kit and fender in sydney,his MFD is working fine..he can even watch DVD on it...pretty sure he is on this club
wiring diagrams for MFD
http://www.skylinesaustralia.com/forums/Wi...ms-t115675.html
more here
http://www.hkskylineclub.com/new/forum_pos...3160&KW=MFD
from the links within links on my previous post... its all there - up to you to modify that to fit your cars wiring.
even to modifications required to input video into the unit is in the HKskylineclub link.
as for the menu system - unfortunately the links to the MFD manuals are not working anylonger.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
