yeah, but it looks out of place you know, i like things being low key, but a monster at the same time aswell.. if you see my car its not really flash, just 17x9's all round, suspension is set up for drift and its low with a type m kit. If you search the forum ull find pics.
https://www.sau.com.au/forums/topic/196578-gt3540/page/3/#findComment-3524456
  • Replies 42
STR8E180 Just had a look at your cars. I dont really like s13's but i love 180's and yours would have to be one of if not the best example ive seen. Everything has been done right and with a purpose looks unreal and makes great power. As for your r32 gtr it's the car i wish i bought instead so need not to say more lol
im gonna be aiming at 400rwkw in the 180 next week, i dont just wana break 400 i wanna go deep into the 400's
the car fly's it just doesnt put power to the ground but it does take corners pretty good for the power its making
https://www.sau.com.au/forums/topic/196578-gt3540/page/3/#findComment-3524806
yeah only problem with that is the more power you make the less response you get, which is great in a straight line but if you try and take a corner at high speeds you dont have the torque to pull yourself out. I'm not talking about drifting either the more grip you have the more torque you need. I guess its all about what you want tho really.
https://www.sau.com.au/forums/topic/196578-gt3540/page/3/#findComment-3526884
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
