Make:
Nissan Skyline
Model:
R33 GTST SII
Milage:
112000ks
Transmission:
manual
Colour:
White
Melbourne Vic (more then happy to drive it up to SA or NSW)
Complied?
Yes
RWC supplied?
Yes
Currently registered?
Yes
Price:
$13500 ono
Contact:
pm or call 0422 225 532
Comments / Modifications:
car is stock as a rock apart from full turbo back exhaust, GTR fuel pump and R34 GTT side mount cooler running stock boost (stock boost is 7psi after cooler and exhaust was added boost went up to 9psi no aftermarket boost controller used).
car has done 112000ks and has had its 100k service done which included brand new water pump and gates timing belt kit done by RE Customs. NGK platinum plugs were put in at 110000ks so no need to be change for another 90000ks. oil used is Motul turbo light oil changed every 5000-6000ks.
Exterior mods: standered Series 2 kit and genuine GTR adjustable rear wing, R34 GTT 17" wheels with 225 fronts 235 rears with 75% tread
Handling: genuine GTR rear strut brace and cusco front strut brace and some sort of firm jap shocks.
car will come with RWC and rego is till jan but will be paid for
feel free to ask any questions.
Images:
https://www.sau.com.au/forums/topic/196687-r33-gtst-s2/
well yes and no lol
would love this gone so i dont have to look at it every time in the garage coz i hate seeing it just sitting in the corner collecting dust but ill wait for the right buyer :)
im away for a week till next friday so if you are interested in the car pls call me instead of posting or sending PM as i wont be able to reply to it till next friday.
https://www.sau.com.au/forums/topic/196687-r33-gtst-s2/#findComment-3553266
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
