Make:
Nissan Skyline
Model:
R33 GTST SII
Milage:
112000ks
Transmission:
manual
Colour:
White
Melbourne Vic (more then happy to drive it up to SA or NSW)
Complied?
Yes
RWC supplied?
Yes
Currently registered?
Yes
Price:
$13500 ono
Contact:
pm or call 0422 225 532
Comments / Modifications:
car is stock as a rock apart from full turbo back exhaust, GTR fuel pump and R34 GTT side mount cooler running stock boost (stock boost is 7psi after cooler and exhaust was added boost went up to 9psi no aftermarket boost controller used).
car has done 112000ks and has had its 100k service done which included brand new water pump and gates timing belt kit done by RE Customs. NGK platinum plugs were put in at 110000ks so no need to be change for another 90000ks. oil used is Motul turbo light oil changed every 5000-6000ks.
Exterior mods: standered Series 2 kit and genuine GTR adjustable rear wing, R34 GTT 17" wheels with 225 fronts 235 rears with 75% tread
Handling: genuine GTR rear strut brace and cusco front strut brace and some sort of firm jap shocks.
car will come with RWC and rego is till jan but will be paid for
feel free to ask any questions.
Images:
https://www.sau.com.au/forums/topic/196687-r33-gtst-s2/
well yes and no lol
would love this gone so i dont have to look at it every time in the garage coz i hate seeing it just sitting in the corner collecting dust but ill wait for the right buyer :)
im away for a week till next friday so if you are interested in the car pls call me instead of posting or sending PM as i wont be able to reply to it till next friday.
https://www.sau.com.au/forums/topic/196687-r33-gtst-s2/#findComment-3553266
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
