Make: S13 SILVIA
Model:SR20DET
Milage:
Transmission:5SPD REBUILT
Colour:SILVER NEW PAINT
Complied? YES
RWC supplied?YES
Currently registered?YES
Price:13500K ONO
Contact:TRENT OR CAT 0414944146 0419590220
Comments / Modifications:SEE BELOW
Images:ATTACHED
Car has brand new 2pack paint (was factory two tone silver and gun metal and i HATE two tone) and genuine uras bodykit, new HSD coil-overs with 3 way adjustment, castor and toe rods, full front and rear skyline R33 brake conversion as well as r33 front control arms, extra lock etc, upgraded lightweight jap swaybars, new URAS wheels and TYRES (decent TOYO tyres no chinese shit), east bear racing bucket (slight rip) . Interior is imaculate and has a MOMO Race not fitted atm the interior is unmarked has late model door trims. it also has a full set of URAS tail lights and clear indicators. Pioneer cd stacker fitted atm or can remove and fit a double din Panasonic cd/md instead.
FMIC, new TRUST T518z turbo, GREDDY Profec E-01, NISMO 550cc, Z32 and new Walbro pump fully tuned PowerFC, new PeII trust cat back with URAS titanium tip extension (not fitted in pics) front pipe and TRUST dump pipe. It also has a NISMO 2-way diff (not to harsh) S14 gearbox.
This is ready to drift competitively and was setup (full suspension setup) up as a spare in case the yellow one was involved in an accident, or alternatively as a very neat streeter.
nice nice trent.. whos is it?
its ours, it has been slowly built up over the past year and a half to use as a spare if cats car is unrepairable between rounds, it is super quick in the hills (where it spends most of its life) and is setup very similar to cats SR20 drifter from last year.... its a very competitive drifter and thrasher but yet has the sleeper look... pretty much a buy and compete type car... but with A/C and a full interior :w00t:
thats nuts.. im tellin ya, if i had the cash id buy it, looks sex.
Goodluck with the sale mate, very very well presented car.
fullboost by?
power figure?
early and lots :ermm:
nah seriously 230-240rwkw with the 550cc's NISMO injectors and i forgot it has SUPERSPARK coils for good measure.
damn only if u guys pumped out the rear guards and some hectic offset rims
been there did that... we had the first real wide drifters in australia 4-5 years back before it became "cool"... this is a streeter designed to attract zero attention yet do everything our race car does... its NEVER been pulled over.
so how are genuine buyers meant to contact you when you clearly ignore pm's and ignore posts in this thread, and you dont provide a phone number?
do you want to sell this or not?
you spend all that time putting up pics of a car that isnt even for sale and dont even reply to my pm or post..
talk about frustrating!
i get about 50 pm's a day and im on holidays atm... all the new info is now up..
230-240rwkw with the 550cc's NISMO injectors and threw in some SUPERSPARK coils for good measure.
Fitted new boost controller today it is a PROFEC E-01 that i had sitting in the study so it now has full control of emanage and boost.
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
