Untamed Performance Cruise (04/01/2008)
Where: City West Parking lot
When: Friday Jan 4th
Who: Untamed Performance (www.untamedcarclub.com)
Meet: 9:00 PM
Depart: 9:45 PM sharp
A Good Mix of Hills, Freeway and back streets. the map has been practiced over the past few months so it will be perfect and defiantly set a standard for 2008. Map will be provided.
Performance Cars only!
No Beeping
No Revving
No Sound systems
Edited by G Boost
https://www.sau.com.au/forums/topic/197411-untamed-performance-cruise-04012008/
  • 4 weeks later...
There is a 20/twenty game of cricket tonight at the WACA. The game finishes about 9.30. Hope your cruise doesnt get caught up in to much traffic/RBT's etc.
As my Skyline is unavailable to me at the moment, i cant go :O
Good luck with your cruise ;)
You need to get off that leash mate!
i know dude,ive found chicks and car cruises dnt work for me,id rather drive alone,or take one of the boys who enjoys a bunch of imports going nuts!!!,all tho last skyline cruise my mate decided to dutch up my car,so by the time we got to midland we decided to ditch the cruise and get munchies,,mmm alfreds kitchen,,
yeh was good, what happened with the first stop at armadale? i got the got out of the car and was told it was wrong place so we drove off and ended up at the next stop, i brang a girl with me for the first time on a cruise n she was too buzy talkin to her friends on the fone and wasnt reading the map
haha, so thats what happened, i was the same, got out the car next to some hot little blondie in a mini truck with tray painted up, walked accross to talk, then we are leaving, some dude said wrong car park, so followed thinking was just around the corner then end up at next meet point...lol... but yeah i feel ya pain bro, the whole bringin the girlfriend thing dont work for me either... instead try bringing some other chick, or one of ya mates, much more fun...mine was asleep through most of it last night....lol
I always bring my mechanic.. he can navigate and if anything breaks.. :) and we usually leave the smoking till we get home :(
